Hello Support,
Is it possible to configure a condition with the cheklist fields ? For example...
My issue is IN PROGRESS status and I would like to permit a transition to the DONE status if and only if all the cheklists tasks are DONE (Checked)
Thank you
Regards
Olivier
Yes. You can have conditions on the transition that will allow it when they are all checked. The transition won't be visible to the user until they are all checked.
