Is it possible to add a pop up box with guidelines for each status in jira workflow
Carina Kærvang
September 26, 2022
We are currently creating a new project in Jira, and in regards to the associated workflow - for each status, we would like some kind of a "pop-up" box to appear, when you move the mouse over each status. This simply to explain our colleagues which tasks to be effected in each status type, before changing to next status type.
It could also be, a text box added below the workflow with help text for each workflow status.
Are the above mentioned suggestions possible? If not - do you have any other suggestions?
Carina
Donika Pacolli
@Mark Segall I'm also new here, and trying to do the same as Carina. I am working on Cloud. Where do I configure the Transition Screen "Pop Up" - I cannot seem to find it in Project Settings.
Thanks in advance!
Donika Pacolli
More specifically, what do you mean by 'create a special transition screen and assign that screen to each of the desired transitions in the workflow'
Mark Segall
February 14, 2023
Hi @Donika Pacolli  and welcome to the community!
Some prerequisites for this:
  1. You need to be Jira Admin
  2. The project needs to be configured as Company Managed
Once you've confirmed that, you'll take these steps:
  1. Navigate to Settings >> Issues >> Custom Fields
  2. Create a new custom field. On the left, select Advanced and then look for Message Custom Field (for view). Give the field a name and In the description type what you want users to see.
  3. From the left navigation, select Screens
  4. Click Add Screen, give it a name like In Progress transition screen (or whatever status you're wanting this applied to and include the field created in step 2 above
  5. From the left navigation, select Workflows
  6. Locate the workflow(s) where you want the text to appear and click the ellipses to the right and select Edit (switch to diagram view)
  7. Click on the transition line that you wish to present the screen.  Details will appear on the right with an Edit button.  Click that and then for screen, select the one created in step 4.
Donika Pacolli
Hi again,
Thank you for your answer. I followed your guide and made it work - the only thing I had to change was to create the field as Message Custom Field (for edit). That was the only way it would appear on the 'resolve' screen, which was the status I wanted the info-box to appear on.
Best
Donika
Like Mark Segall likes this
Mark Segall
February 15, 2023
Ahh, you're right.  The view version is just for view screens.  Good catch.
Amit Kumar Singh
@Donika Pacolli Message Custom Field (for edit or View) not working in Jira Service Management, it was earlier working when i was using Jira Service Desk, is there any way we can add a text message to pop-up transition screens?
Mark Segall
September 26, 2022
Hi @Carina Kærvang and welcome to the community!
Are you on Jira DC/Server or cloud?
If you're on cloud, you have a couple options:
1. Static Message Custom Field on the issue screen
The Message Custom Field is a field where you set static text.  You can add it to the issue screen and as users get more savvy with the workflow, they can either pin more important fields above it or you can eventually just hide it from the screen.
2. Transition Screen "Pop Up"
Similar to above, you'd create a Message Custom Field, but instead of adding it to the issue screen, you'd create a special transition screen and assign that screen to each of the desired transitions in the workflow.
I highly recommend not going this route because your more savvy users will get frustrated quickly at having an extra click every time they want to transition an issue.
Carina Kærvang
September 26, 2022
Hi Mark
Thanks, and thank you for your reply.
We are on server 😬. Are there any options then?
Br
Carina
Mark Segall
September 27, 2022
