Is it possible to add the issue security level field and the assignee field to the form?
Simon Huprich
based on a user requirement I would like to ask if there is a possibility to add the issue security level field and the assignee field to the form in JIRA work management.
I already added the fields to the specific screen but the don´t show up at the "form-building-page".
Greetings
Simon
Alex Koxaras -Relational-
Hi @Simon Huprich
Yes it is possible. You only have to add them on the desirable screens (create/edit/view) and just to make sure that you have set up the appropriate issue security scheme (and the corresponding levels).
To add the fields:
  • go to project settings
  • screens
  • Click on the screens you see
    • search for fields and click add
For the issue level security (If you haven't already set it up )
  • Go to cog > issues
  • Issue security schemes
  • Add issue security scheme
  • Configure security levels THEN
  • go to project settings > issue security
  • Click Actions > select scheme
  • Choose the scheme you have already created
Simon Huprich
Hi Alex,
Yes I already had all the adjustments you are mentioning.
But I would like to modify the field "Assignee" and "issue security level" not on the issue create screen but in the "form" of Jira work management.
Greetings
Simon
@Simon Huprich I misread your question. You were about inserting the fields in the form on your project. Sorry, but according to the documentation this isn't possible.
Simon Huprich
OK!
Thank you for your answer!
Numarena BV October 18, 2022
Hi Alex!
I look at the list of custom fields, I can't find the security level field.
So, I can't display the security level field in my issue.
Can you help me?
Ajay _view26_
Hi Simon,
Can you share the screen which has the fields added?
Simon Huprich
there you can see the uses screen:
Assignee and Security Level are on it.
But in the form-building view I cann´t find them:
Simon Huprich
atlassian, team ’25 europe guide, teamwork collection, atlassian events, conference guide, team culture, collaboration tools, ai in teamwork, atlassian learning, event schedule, keynote previews, community events
Must attend events for Team Europe '25!
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
