Is it possible to add users using REST
Sverre July 19, 2012
We would like to add users by using our onboarding solution and stop adding them manually.
Leroy Elendt
Hello, currently the REST-API is still under development and not the amount methods is still not as high as the SOAP-API provides.
Currently there is no API for REST to add users (here is the latest REST-API) but you can do it with SOAP (look here under UserManagement): void addUser(String token, User user, String password) - add a new user with the given password.
alternative you can write your own REST-API
hope this is what you were asking for :)
Perfect, just what I needed :)
Alejandro Conde Carrillo
July 19, 2012
Hi.
Yes, you can add users throug the API. Here you have a link to the section in the documentation: https://developer.atlassian.com/display/CONFDEV/Confluence+XML-RPC+and+SOAP+APIs
There is a section for user management.
Excellent, thanks
Abdoulaye Kindy Diallo
July 19, 2012
REST is already enabled by default. For more information on the usage, see https://developer.atlassian.com/display/JIRADEV/JIRA+Remote+API+Reference
Hi Abdoulaye,
Thanks, but the question was "is is possible to add users using REST?
Best,
Sverre
Register now
