I need help to set up automation which will change custom filed (one choice list type) value depending on issue type and status change.
e.g. : issue "Task" with status "in progress" change to status "done" which will trigger custom field change for speciffic value.
Hi @Piotr Nowak
Yes it's possible.
Trigger: transition status from and to
Condition: issue type = task
Action: edit issue and the field you want
Help us plant more trees
