Is it possible to avoid editing a subtask, depending on the project role
marina-s November 13, 2019
hello
i want to avoid editing  subtask everyone except Devmanager (project role)
adding properties not worked
property key=jira.permission.subtasks.edit.denied.projectrole
property value=10100
i'd be happy to get recommedations
thanks
Madineni March 12, 2021
Hi All,
I just tried the following property in Parent task when it is in a status xyz to restrict transition of subtask.
But its not working. Any suggestions on this.
SWAPNIL SRIVASTAV
Hello @Madineni ,
Could you please elaborate your purpose/requirement.
SWAPNIL SRIVASTAV
Hi @marina-s ,
You can add property as:
Property Key: jira.permission.edit.projectrole
Property Value: <id of project role whom you want to give permission>
on every single status of the workflow and then publish it. If the workflow is shared among other issue types as well, the restrictions will reflect there as well. If you don't want that, copy the current workflow and add property there.
Best Regards,
Swapnil Srivastav
Nir Haimov
You can do that by putting "sub-task" under separate workflow.
Than add the entire workflow status with property:
jira.permission.edit.role=your_role
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
