Hi all, I am traying to block the possibility to create a new branch by development panel in Jira when an issue is in "Closed" state.
I am trying by adding new Property in the "Workflow Step Properties", but at the moment I did not find a solution.
I tried "jira.permission.viewversioncontrol.denied", but the Development panel totally disappeared and I want instead to see the commit/branch/pullrequest created in the steps before.
I tried also "jira.issue.editable with false" or "jira.permission.edit.denied", but it seems that they are not related to development panel so I was able to create a new branch.
Do you have any suggestion?
Hi @Maria Luce Congedo
I hope you are well.
This is currently an open feature on Jira Software reported in JSWSERVER-20353 -- Disable "create branch" option depending on issue status.
You might be able to get that working with a JavaScript code hiding the HTML element on selected screens.
Here's an example that will hide the Create Branch element on most screens (it may not work on boards).
<script type="module">
// list of allowed issue status
var allowedIssueStatus = ['Unresolved'];
// When opening an issue from the Issue View
AJS.toInit(function(){
//get status of the issue
var currentIssueResolution = (AJS.$('span#resolution-val')[0]);
if (document.URL.indexOf("/browse") >= 0 && (currentIssueResolution != undefined && AJS.$.inArray(currentIssueResolution.innerText, allowedIssueStatus) < 0)){
AJS.$('.devstatus-cta-link').hide();
// When opening an issue from the issue queue and search
$( document ).ajaxComplete(function( event,request, settings ) {
if (
(document.URL.indexOf("/secure/RapidBoard.jspa") >= 0 && settings.url.indexOf('/issue/details.json') >= 0) ||
(document.URL.indexOf("/browse") >= 0 && settings.url.indexOf('AjaxIssueAction!default.jspa') >= 0) ||
(document.URL.indexOf("/projects") >= 0 && document.URL.indexOf("/issues") >= 0 && settings.url.indexOf('AjaxIssueAction!default.jspa') >= 0)
// hide
if(currentIssueResolution != undefined && AJS.$.inArray(currentIssueResolution.innerText, allowedIssueStatus) < 0){
</script>
Thiago Masutti
Learn more
