Is it possible to change the created date of a JIRA issue?
Shreena Patel
Is there a way to set a JIRA task's dates to a specific date rather than always "today"? I sometimes have to create a task days after the task has been done.
Nic Brough -Adaptavist-
March 27, 2014
No, the created date is always the date you physically created the issue.
The exception is if you import issues with CSV, you can set it in that data. But you can't change it.
If you're logging issues and need to record a different date/time to when you're typing, most people use a custom field to record the actual date.
John Drotar
I found that by doing a CSV upload through the settings and not from the issues page you can in fact modify the creation date as it provides more options for field mapping.
Like • it.helsinki: JIRA Admin likes this
Sanjay Bhan
February 7, 2019
i didnt see system generated fields in that mapping, any way to enable them ?
John Drotar
You need to have Jira Admin rights to start.
Step 1 Click on the 'settings' cog on the bottom left of the screen.
Step 2 Click on System
Step 3 Click on External System Import under the "Import and Export" category
Happy importing!
Like • 3 people like this
Oleksii May 14, 2019
@Jorge Miguel Zambada , I'm doing it by csv import. There i can define any created date same as dates for comments etc. Actually,by csv import you can do almost everything, but you have to use system import tool which are on System tab (only available for jira admin users).
Vinod Harambe May 24, 2017
It can be done if you are using the JIRA import functionality. Map the task creation date in the CSV file to the "Created Date" feild in the JIRA import page. It will automatically choose the date from the CSV and not generate the created date as NOW by default.
Ryan Williams
May 2, 2018
Created Date field is not present in the drop down list.
== Jira Fields ==
Summary
Issue Type
Component/s
Description
Fix Version/s
Priority
Labels
Environment
Affects Version/s
Assignee
Like • Samir MEZIANI likes this
John Drotar
I also don't see the field in the uploader.
venugoplala naidu November 24, 2018
Search for "Date Created" while mapping not created date
November 25, 2018
When this question was asked, almost 5 years ago, you could import the created date.
Now, you can not, it really does reflect the date and time you created the issue.
Like • 2 people like this
Oleksii March 5, 2019
Still working fine with Jira Admin rights
May 13, 2019
Oleksii Zatulskyi how you can see the created date field to import ?
Like • Amaury_CARCENAC likes this
Mehmet Kazgan
March 27, 2014
I don't think you can do that other than the database.
