  • Community
  • Q&A
  • Jira
  • Questions
  • Is it possible to change the status of an issue in relation to another issue wich is blocking it?
María López Carrasco November 22, 2018
I would like to know if when I link an issue with the relation "blocked by" is possible to change the status of the blocked issue. I mean:
  • I create an issue. Issue A --> status: Backlog
  • I add a link to issue A. Linked issues: is blocked by issue B
  • Issue A status changes to Blocked (automatically?)
  • when issue B is in status Released, issue A chages status to Backlog again
As I was writing it, it sounded more impossible. Does anyone know if is possible to configure something like this?
Thank you :)
Shawn Masters
November 22, 2018
Jira Workflow Extensions can do this via Post Functions in the workflow. JWME on the marketplace i think.
Shawn Masters
November 22, 2018
Additionally, Automation for Jira, can also accomplish this
We've been trying different extensions for that and they work pretty well. I just wanted to know if there were any way to do that without an extension.
Thank you so much anyway!
Shawn Masters
November 23, 2018
I havent encountered any method on the Cloud version outside of those mentioned. You might be able to do something in the Rest API im not aware of, but would require a developer resource.
María López Carrasco November 26, 2018
It is ok, thank you so much for your time! :)
