In Cloud, using a next-gen project as a demo. The board that's created by default is Kanban. Next-gen projects can only have three statuses: to do, in progress, and done. The board uses fixed-width columns, as far as I can tell, which means that the columns on a large monitor are very narrow, causing content to wrap, even though there's a ton of white space off to the right.
Is there any way to change the column widths, or make them responsive?
Hi, is this going to be fixed/implemented, since it looks ridiculous, especially on large screens? For example on QHD resolution
I'm thinking of going back to Excel sheets.
This next-gen starts to look like lost-gen project. 2 years and still no adjustable columns... rubbish.
Another half of year passed and I still do not see this basic functionality :(
Did you give up waiting?
Yeah, I gave up waiting... the only change they did was with upgrade of layout which is much bigger that old one, so white space now is smaller. Also they removed old types of project, where columns adjusted their width. This is sad :(
Yall some hoes for not allowing us to resize columns.
vote +1
Any news about this?
Any registered feature request we could vote for?
Please make it responsive, it is even painful to look at this :(
Today I also created a next-gen project and this bugged me a lot. Since the seems not to be a solution I created css and inject it with a chrome extension e.g. "Styler".
This may not work for every configuration and also break if they change something in their code so you may need to adapt it:
Nice
I'll try to use it.
Too bad, they didnt fix it for 5 years now...
Yeah that is really ridiculous...
I think that is the problem with monopolies, at some point they do not feel like they have to be customer friendly anymore :)
Had to add some, to fix the columns and issuecards
+1
After almost 3 years waiting, it's clear we won't get it. Is there any hack we can do client side (some Javascript?) to change the CSS of the columns and have them use the full width?
+1
adding another vote for making Kanban board column width adjustable.
You know why they've done it this way? It's because the next gen boards almost certainly are using Trello code and that was always an annoying thing about Trello – narrow as hell columns.
It's been 2 years since this question was asked and apparently wider columns is too "next-gen" for these Next Gen boards
+1 for adjustable column width
+1
+1
+1
+1
+1
vote +1
+1 :-)
