I want to get number of times the issue made some transaction.
Suppose my workflow has Ready to Retest--> Reopen. Now if 1 issues is marked as ready to retest but it was reopened, again after fixing that issue was marked ready to retest but again tester reopens the issue.
Considering above scenario I want to know how many times the issue was reopened.(need its count)
Thanks in Advance.
Found another simple way to do this:
Set up a rule on your project to listen for a specific issue transition (either using JQL condition or the transition options, then add an Edit issue action.
Select the field you want (My Customfield) to increment and use the following value:
{{#increment}}{{issue.My Customfield}}{{/}}
This will increase the value every time the issue goes into that status.
Found this from @Nick Menere
Hi @Veronica Mapes , I was trying to implement your solution and I continue to get this error: Error while parsing additional fields. Not valid JSON.
Would you mind looking at my screenshot and tell me where I'm going wrong? I know it's user error I just don't know what I'm failing to do.
Thank you,
Christine
@Christine Corona - It looks like you have spaces between the brackets, though I can't be sure. If so, try removing those. If not, I'm not sure =/
Thanks @Veronica Mapes, I indeed had spaces so I removed those. I also needed to remove the value from the Additional fields section and place it only under the identified custom field section, then it worked perfectly!
Hi Veronica and Christine,
I'm also finding this way to count my transition and it is working. Thanks a lot!.
So I just want to share an image of what does Christine said about remove value from the additional field section and place it under identified custom field section. Bcos previously I could not understand it. Probably this can help others too. <3
Hi Akshay,
Do you have Jira Misc Workflow Extensions plugin in your Cloud instance? If yes,
Now every time the ticket is reopened the "Reopened Count" field value increments by 1.
Hope this helps,
Radhika
I found a free plug in https://marketplace.atlassian.com/apps/27136/jira-misc-custom-fields?hosting=server&tab=overview
that has the functionalty of your needs. You can check that one. As Elifcan mentioned above, its not easly possible to find transtion count without searching history tab.
Create calculated custom fields that evaluate a Java expression to compute the value of the field. Can be of type Number, Date or String.
Create custom fields that will hold the date/time or the name of the caller of any transition in your workflow.
Additional JQL functions you can use in your issue filters.
The Jira Misc Custom Fields plugin's objective is to provide several new types of custom fields for use in custom Jira workflows as well as useful JQL functions.
Included custom fields:
Included JQL function:
@Burak Kocak Thank you for your suggestion too.. but may be Jira Misc Custom Fields plugin is available for server and we are using cloud version.
hey Burak ... I know it's a lot time ago, but JMCF plugin is not free anymore ... do you have other suggestion to do the same for FREE ? thx !!!
I don't think it's possible without any add-ons. For example with Script Runner plugin you can define a scenario like this:
It is the best possible solution that I can think of on Cloud.
Elifcan
@Elifcan Cakmak Thank you for the valuable suggestion. But can I get the count of transactions which are already made.
Hey,
I'm afraid there is no automatic way to get that number. You can check issues one by one, you can see the transitions made on the transition tab but I'm sure you already know that and it is not an ideal solution. I'm sorry I couldn't be more help.
Elifcan
Hi @Elifcan Cakmak ,
Regarding your solution with ScriptRunner:
I am new to JIRA and ScriptRunner - do you have an example of how can that script look like?
Read the story
