Is it possible to create group of organisations?
Debora Silva July 6, 2021
I would like to create three different groups to include my customers and map them to different SLAs through JQL.
e.g., EU customers, US customers, APAC customers.
It's possible? Or is there at least a way to do something similar?
Actually, I've already done what you mentioned @Dirk Ronsmans
However, I need a way to segregate customers into three groups to associate them with different SLAs. Otherwise, I will have to manually associate them one by one, at the risk of forgetting any new ones that will be created in the future.
Dirk Ronsmans
Well if you have the organisations (those you will have to maintain manually) you can set your sla goals based on the organisation
what exactly isn’t working?
Using reporter in organizationMembers? If so, assuming I have more than a thousand customers, should I enter one by one into organizationMembers? Or is there another option I'm missing?
Dirk Ronsmans
July 6, 2021 edited
Hi @Debora Silva ,
grouping customers in to organisations is perfectly possible. Putting these organisations in to groups unfortunately not.
so only one level.
As you mention customers, this is exclusive to JSM tho
https://confluence.atlassian.com/servicedeskcloud/blog/2016/09/group-customers-in-organizations
https://support.atlassian.com/jira-service-management-cloud/docs/group-customers-into-organizations/
Help us plant more trees
