hello All,
Basically we have some custom fields on create screen and to view the values of these field we want to use table. So, custom field value should be display on table cells.
Thanks in Advance!
Can you explain this in more detail? Values from fields should be in "Description" where you will put the table?
Or maybe you want a table, as a custom field with another fields in it as values?
Currently, the most usefull addon would be Table Grid Next Generation.
But I can see, that you have scriptrunner tagged there. One of the solutions might be script listener, that will edit the Description of an issue. You can populate table in Description with the values from custom fields.
