Is it possible to expand and collapse all gadgets on a dashboard?
jira_learner
Hello all,
Just wondering if it is possible to expand and collapse all gadgets on a dashboard?
This function can come in handy when I review my dashboard with the team one gadget at a time. Once everything is set up, I don’t have to expand each gadget individually—I can expand all of them in one go.
Utkarsh Agarwal
Hi @jira_learner
There used to be a suggestion which was closed due to low engagement: https://jira.atlassian.com/browse/JRACLOUD-24339
Currently, there’s no bulk expand/collapse, but you can simplify the view by switching to a single-column layout, splitting gadgets across multiple dashboards, or using apps like Rich Filters for tabbed/grouped views as an alternative.
Hope this helps!
Kind Regards
Utkarsh
Dwight Holman
July 16, 2025
No - there is no built-in feature in Jira to do this. Neither could I find a marketplace apps to add this feature.
If have a paid-plan you could make a product suggestion.
jira_learner
Thank you for the replies.
I will sort them manually.
