I need to get set of SprintMarkers for concrete issue from my code and add linked issues to the same Spring Marker.
Sprint Marker is a "draft Sprint", on "Plan" board, before pressing "Start Sprint". After pressing "Start Sprint" GH removes this object from DB and creates Sprint object. There is table "AO_??????_SPRINTMARKER", which contains this objects persisted.
I've read almost all the documentation about GH's API, but found nothing about this question. I guess, this is impossible without hacking GH. Is it correct or not?
I saw question https://answers.atlassian.com/questions/105079/can-i-query-by-sprint-that-was-not-started-to-report-my-plan. It is not the same thing.
You can also do it using REST - The REST url is rest/greenhopper/1.0/api/rank/after
A sample JSON payload is from my browser is:
{"rankables":[{"id":2,"type":"sprintmarker"}],"customFieldId":10206,"rankAfterKey":"LLLLL-7"}
Thank you very much. I'll try. But I need to add issues to sprintmarker by event, so I have to use Java/Groovy listener. Is there some GH's API for this?
Thanks! Investigation in GH's REST code gave me required pieces of code.
I would refer to Shawn's comments here: https://answers.atlassian.com/questions/96142/how-to-get-sprint-issue-list-by-sql
As far as I know, any issue can be in only one planned sprint in any given board. But, I believe it can be in different planned sprints on different boards, so I think you will need to traverse the ranking table as Shawn describes, for each board.
Yep... there is a lot of good info there... in fact that's pretty much the sum of human knowledge outside Atlassian about how GH stores its data.
But the problem now is to add another issue to found sprint marker. Do you think it is possible?
It's possible if there is a remote or java API for it... whether they make it easy to access that API is another matter. To be honest I don't know, I'd consider asking a new question.
Help us plant more trees
