When creating an issue from an Epic in Jira Cloud, I've noticed that it doesn't show the full create screen pop up like it does in Jira Server/Data Center. Users are unable to create certain issue types from epics if those issuetypes have a 'Fields Required' validator when creating that issue type.
Is there a way to get the full create screen to show when creating an issuetype from an Epic?
I know it works for Required from Field Configuration, but not for Field Required validator
Hey Itamar!
Got it - I am using the Fields Required Validator within the workflow so that's probably why I'm experiencing this issue.
Hello @rneill19
When you say you are creating an issue from an Epic, do you mean you are adding a child issue? And from the Epic it is just adding a line under Child Issues for you to enter the Summary?
It should automatically open a dialog for entering data in other issue fields when either a field has been set as required in the Field Configuration or a Validator is requiring a field to be set. Is that not what you are experiencing? If not, can you provide more details about the exact experience your users are having?
