Is it possible to populate native versions fields while creating an issue via API
Antoine _Klee Group_
August 10, 2021 edited
I want to create an issue in Jira using the Rest API.
Here is the JSON I am sending.
    "fields": {
        "project": {
            "key""KEY"
        "summary""Populating affects version",
        "issuetype": {
            "name""Bug"
        "versions":[{ "name": "1.0" }]
 This works just fine when the name of the version already exists in the project but prompts an error if not.
"errors": {"versions""version name '1.1' is not valid"}
Is there a way to populate the "affects version" (or any versions field) field if the value does not yet exist within the project?
Thanks.
Alex Koxaras -Relational-
HI @Antoine _Klee Group_ ,
The reason why most likely this is happening, is because you are sending a request to create a new issue, and not a new version (which relates to the project) To create a new version you must follow this API:
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-project-versions/#api-rest-api-3-version-post
You could somehow use the native automation, which has the ability to create a new version.
Alex
August 10, 2021
Thanks that is what I did in the end. I was actually wondering is there was any way to create versions "on the fly". Aka if it does not already exist then it is created.
Infact there does not seems to.
Like • Alex Koxaras -Relational- likes this
It's good that you did that @Antoine _Klee Group_! Well done!
Kindly mark this answer as accepted, so as to help other people in this community to find the right answer to similar question.
Thanx!
Like • Antoine _Klee Group_ likes this
