×If there are any updates in the start or due dates of a story, it is possible to see it only in the history of the task.
Is there any methods to see these changes directly highlighted in the timeline overview without going back to history of each stories?
Hi @Aleena
No this is not an option, but you should notice the shift in the time lines.
Otherwise you can always create an automation rule that based on a change to one of the fields, sets a different custom field and create a filter on this and show this on a dashboard.
Hi @Aleena
It's possible with workarounds like custom field+automation or plugins. For example, you can filter any field with Issue History for Jira (the app developed by my team).
Due date changes of a single task:
Due date changes for multiple tasks in your project:
Read more here: How to see due date changes in Jira
