Is it possible to set originalEstimate via CURL?
Lee Correll
May 10, 2012
I've searched thru the answers here (and via google) but I can't seem to find out if it's possible to set the Original Hours field via a CURL update. I can set fixversion, assignee, etc.
I'm using:
curl -X PUT --data @[json below] [our URL]
I also tried:
curl -X POST --data @[json below] [our URL] (and got HTTP method not allowed for the requested resource)
My json file is one line:
{"update":{"timetracking":{"originalEstimate":"4h"}}}
Am I looking in the wrong place?
Dieter
May 10, 2012
Did you already check the example at https://developer.atlassian.com/display/JIRADEV/JIRA+REST+API+Example+-+Create+Issue#JIRARESTAPIExample-CreateIssue-Addingaworklogentryduringcreate ?
It mentions that you should also disable the legacy time tracking mode to be able to change other time tracking fields than remaining estimate
Lee Correll
May 10, 2012
I'm using ondemand, so I believe that time tracking mode isn't mine to enable/disable - ergo, it's disabled. The example there is what i used to derive my JSON to begin with - there's just not an example of it being "updatable" - which is different from generating it when the issue is created.
Dieter
May 10, 2012
I have just verified that the following works for me in 5.1-m3. I hope it works on OnDemand too.
   "fields": {
        "timetracking":
           "originalEstimate": "11d 2h",
           "remainingEstimate": "3h 26m"
Dieter
May 10, 2012
BTW: I have verified it using the REST API browser which comes with the Atlassian Developer Toolbox plugin. Cool stuff!
I have used PUT
Lee Correll
May 11, 2012
Ah, when I tried to set both the original and the remaining estimates - it worked. Thanks!
Joe Clark
May 10, 2012
Are you able to modify the original estimate through the main JIRA interface? Check to make sure that you have disabled 'legacy time tracking' in JIRA's admin interface - http://confluence.atlassian.com/display/JIRA/Configuring+Time+Tracking#ConfiguringTimeTracking-configuringtimetracking
Also ensure that the user you are logging in with via curl has permission to modify the time estimates. :-)
Lee Correll
May 10, 2012
Yes, I can edit it via the web interface; we're on OnDemand, so legacy time tracking isn't the problem. :)
