If I have an items linked to a story, is it possible to have Fix Version, show these items?
So we wanted to have Epic > Story > Task > Sub task (we needed the extra layer) but you cant create a task from story, so we linked them together. Now using Fix versions the tasks are not appearing, they all have fixed versions on them, but do not have epic links.
So if you click on a version then on an epic I see nothing and I want to see the tasks linked to the stories. Is this possible?
Hi @Sarah Jones
If you are ok for a marketplace app, to visualize your Links & Epic Hierarchy, we have created an add on for this need
Agile Tools - Epic Tree, Links Tree and Time in Status
You can also view the full Jira Issue Type hierarchy of Linked issues, Portfolio/Advanced Roadmaps, Epics, and Subtasks up to 10 levels.
You can filter for fixed version of your projects too.
Key features :
Along with this there are multiple other features like Time in Status, Worklogs reports etc which the app provides.
Disclaimer: I work for RVS, the vendor for this app, and I am one of the developers of the app
Sadly I am not sure an app will be approved, but will definitely look into it. Thank you.
Hi Sarah,
Assuming you want to see them on the epic view, I think you will need to rely on 3rd party apps.
You could use apps like "Issue Matrix" and "Stagil Assets", which will enhance the linked issues section on your Epic View (You can use JQL to filter any issue relations/custom fields, etc.)
I hope that helps.
Melo
