Is it possible to tell if I am connected to an on-demand instance or a server instance using the JIRA API?
Guy Matz
Hi!  Using the REST API - or some other mechanism - Is it possible to tell if I am connected to a server instance or an on-demand instance?
mlassau_atlassian
March 31, 2016
AFAIK there is no reliable way to do this in REST.
Sounds like a good feature request smile
The way I usually tell in the UI is by looking at the footer.
Server will have "Atlassian JIRA Project Management Software".
Cloud will have "Powered by Atlassian
Guy Matz
I did it!!  https://jira.atlassian.com/browse/JRA-60416
I found it very awkward to word that request . . .  are the two types of servers "onDemand" and "Server"?  "Server" is not very descriptive . . .  and now that I think of it, "onDemand" is now cloud.
Please feel free to update the ticket if you have any thoughts, or send them to me and I will update if you are not able to!  Thanks!!!
mlassau_atlassian
April 3, 2016
Thanks for raising that.
Yep - "Server" can be ambiguous, but Marketing obviously think it's a good name, so who am I to argue cheeky
(Internally we often say "BTF" - Behind The Firewall - for On Premises installs but that's misleading too because our Cloud instances are all behind a firewall too)
I might change "Server type" to "Deployment type" in the issue.
Guy Matz
Backups and re-indexing - possibly others? -  work/behave differently between the two versions . . .  I would like to add some code to the jira python client to behave appropriately depending on the context.
Thanks!!
Robert Massaioli (Atlassian)
March 31, 2016
Why do you need to know the difference?
Andrew Frayling
March 31, 2016
You could call /rest/api/2/serverInfo and look at the version element. For on-demand the version is something like:
"version":"7.2.0-OD-05-022"
i.e. it has OD in it.
and for server it's just:
"version": "6.2.5"
Not sure if that's good enough?
mlassau_atlassian
March 31, 2016
If you see "-OD-" in the version then it is definitely Cloud.
Unfortunately the reverse is not true.
Sometimes cloud will have (eg) version "7.2.0" (then two weeks later it will move to "7.3.0-OD-01-xxx")
Another heuristic is the domain name ... eg if it is on "*.atlassian.net" (or one of a few others) then it is Cloud.
But this too is unreliable because that list could expand or change in the long term.
Learn more
