While working with JWT plugin, is it possible to trigger an automation rule when an issue link is deleted ?
Also, can we have 2 automation triggers for an automation rule?
Using the JIRA automation rules, it is possible to trigger a rule when an issue is deleted.
Regarding 2 automation triggers, some of the triggers support multiple values, but there does not appear to be a way to have two different triggers. As a work-around, you could:
Best regards,
Hello, and sorry that I missed the link part of your request.
Looking at the automation rule triggers, it does seem like you can trigger on a link delete also. Please look here for more information:
https://support.atlassian.com/jira-software-cloud/docs/automation-triggers/
Hello @Bill Sheboy ,
Thanks for the reply.
I am working on JIRA software and this link is for JIRA Cloud.
Sorry, I missed that you were on Server version. Here is the document for that version, including the link delete trigger:
https://confluence.atlassian.com/automation/triggers-993924804.html
Thank you for the reply.
Please correct me if I am wrong but the links you are giving me are not for JWT (JIRA Workflow Toolbox)plugin provided by Decadis. I am looking for Automation Rules of JWT plugin.
Thank you for clarifying. I believe you will need to directly contact that markeplace vendor for help, or wait until one of their staff responds to your question.
I added their name as a tag to this question to raise the visibility.
