Is it possible to use context parameters in condition value?
Rafał Janiczak
Hi
I have a question as in the topic.
I've just wanted to use condition parameters to determine when my web panel should be visible.
I've decided to use condition parameters with stored property
https://developer.atlassian.com/static/connect/docs/latest/concepts/conditions.html#static-condition-parameters
Example:
- Property
PROPERTY_KEY = myproperty
VALUE = {"id":"10002","key":"PROJECT KEY","name":"Project Name"}
- Condition
   "condition":"entity_property_equal_to",
   "params":{
      "entity":"addon",
      "propertyKey":"myproperty",
      "objectName":"id",
      "value":"{project.id}"
When I set value in condition to "10002" everythings works fine, but when I try to use context parameters, I get an exception during installation:
Installation failed. The add-on includes a web fragment condition (entity_property_equal_to) with invalid parameters (Could not parse the value provided).
So, Is there any way to use context parameters in condtion?
Best Regards
Rafał Janiczak
Robert Massaioli _Atlassian_
June 19, 2016
Unfortunately the ability to use context parameters in entity_property_equal_to condition values has not yet been implemented; but it is an open issue: https://ecosystem.atlassian.net/browse/AC-1608
I have added this Atlassian Answer to the issue. Please feel free to watch, vote and comment on that issue. I can tell you that, at this point in time, it is not on our list of short term priorities. However, if it gets enough votes then that could change.
