Is it possible to use more than on plugin simultaneously?
Davide Paleari
I would like to enrich the JSD workflow options by installing a plugin. I see there are two free well-rated plugins regarding worflow: JIRA Suite Utilities and JIRA Misc Workflow Extensions Documentation. Mu question is: is it possible to install both and use them simultaneously. If not, what do you suggest?
Thank you, best regards
Nic Brough -Adaptavist-
February 19, 2015
Yes, it's fine to use both.
Read the story
