Is possible to have more than one parent link to one epic ?
Gabriela-Rodica Stroe
January 30, 2023
In order to have a complete view plan, I need to set more than one parent link for one epic.
Is this possible and if so how I can enable this feature ?
Thank you
Mikael Sandberg
Hi @Gabriela-Rodica Stroe,
No, the parent link is a single select field, so you cannot set more than one parent.
herry musk
January 30, 2023 edited
In Jira Portfolio it's only possible to have one parent - so in your case, an Epic can only have one Parent Initiative, not multiple. If you were to have a multi-to-multi relationship, you'd need to use Issue Links.
Read the story
