I attempted to add an Issue Collector to a new company-managed project I created based on the Bug tracking template, but after populating the fields and clicking Submit, nothing is created and I am returned to the "Add issue collector" form screen.
Also, I am only able to select the Custom template as the "Got feedback?" and "Raise a bug" templates are greyed out with the following message displayed:
The issue type you've chosen requires fields other than 'Summary' to create issues. Only custom templates can be created since 'Raise a bug' and 'Got feedback?' will not be able to populate other required fields.
This behavior and message is displayed no matter what Issue Type I try to select/use for the Issue Collector.
Any thoughts, ideas or suggestions?
Is the Issue Collector functionality even available in Jira Cloud Free version?
Thanks in advance for your support.
Issue collector is available on the free plan. Read more here https://support.atlassian.com/jira-cloud-administration/docs/use-the-issue-collector/
Thanks for the quick reply Alex. Yes, I reviewed that doc before submitting my post, and followed the instructions on how to add an issue collector, but still no luck. The page flashes and then I am back to the form, but the issue collector is not created and it doesn't matter what issue type I try to use in my configuration, I am limited to selecting the Custom template only. The other two are greyed out and I continually get the message I mentioned above.
I come from a Jira Server background, so it is a little frustrating to not be able to review logs to try to troubleshoot the issue, especially when no warnings or errors are displayed when I hit submit and all it does is refresh the form with my configuration data.
Any other thoughts or things to possibly try or review?
Thanks for your support.
Hi @Terry Beavers @Alex Koxaras -Relational-
I am also facing same issue :(
Did you get to find out a fix for this issue?
Regards
Rohit
Hi @Rohit Peddakotla, not sure what happened with our instance, maybe an Atlassian version upgrade that fixed the issue as I was able at least create an issue collector now.
With that said though, I am still getting the message about custom templates only.
Sorry I couldn't be of more help.
Terry
Read the story
