Is the time option the same as Advanced Roadmaps?
Donte Crawford February 18, 2024
Trudy Claspill
February 18, 2024
Hello @Donte Crawford
No, it is not. It has some similar functionality, but it is a "basic" roadmap/timeline function.
For more information on the Timeline functionality refer to
https://www.atlassian.com/software/jira/guides/basic-roadmaps/overview#timeline
For more information on Advanced Roadmaps, which is available only with the Premium and Enterprise subscriptions, refer to
https://www.atlassian.com/software/jira/guides/advanced-roadmaps/overview#what-is-advanced-planning
For some high level information about the differences, refer to this page where you can switch between information for the Basic and Advanced features.
https://www.atlassian.com/software/jira/features/roadmaps?tab=basic
Donte Crawford February 19, 2024
Thank you, which option (screen) do I need to access Advanced Roadmaps after purchasing the free trial?
Trudy Claspill
February 19, 2024
Advanced Roadmaps functionality is accessed through the Plans menu.
I provided a link to the documentation in my first response. That includes an overview and links to more detailed documents.
Donte Crawford February 20, 2024
Understood. So Roadmaps is a build in feature within Plans. Once roadmaps is enabled, will I see it mentioned in the side menu? I dont see it appearing on my Jira yet.
Trudy Claspill
February 20, 2024
"Advanced Roadmaps" is the over-arching name (the original name) for the functionality encompassed under the Plans menu. There is not specific item named "Roadmaps" anymore.
Where items used to be named "Roadmap" they have been renamed "Timeline".
The Timeline option you see in the left panel when viewing an agile board is the "Basic Roadmaps" functionality. The Timeline option you see in the left panel when you view a Plan from the Plans menu is the "Advanced Roadmaps" version of the Timeline. These two timeline features provide different functionality.
Youve been extremely helpful, thank you
Trudy Claspill
February 21, 2024
I'm glad I was able to help you.
If all your questions have been addressed, please consider clicking on the Accept Answer button. This helps other people searching for answers find the posts with validated answers.
Donte Crawford February 21, 2024
Last question - what do the different colors represent in the timeline view? Screenshot 2024-02-21 at 9.06.46 PM.png
Trudy Claspill
February 21, 2024
I believe those colors correspond to the Status Category of the issue on the same line.
Gray = To Do
Blue = In Progress
Green = Done
Every individual possible Status value that can be used on an issue is created in one of the three above Status Categories. The Status itself will show the same color coding to indicate the Status Category to which it belongs.
Like • Walter Buggenhout likes this
Donte Crawford February 22, 2024
Thank you. Im unsure of the issue but Ive created a new plan and when I select 'Sprints' in the filter, its showing all sprints as external and no longer displaying the same timeline view. How can I correct this? Screenshot 2024-02-22 at 6.09.24 AM.png
Trudy Claspill
February 22, 2024
Take a look at this:
what are external sprints in advanced roadmaps
(Found by using google to search for (jira cloud "advanced roadmaps" "external sprint")
Donte Crawford February 26, 2024
Thank you. It appears Jira has removed the 'Shared teams' option in Plans. Unsure if it is affecting my new challenge.
When I want to view my capacity management timeline, I change the 'grouped by' option to 'Teams' Im unable to view the assigned team's work. All of my issues show up under 'Unassigned'
Do I need to enable the teams field on my Jira issues? Im currently using component's but when I change the grouped by option to components im still unable to view the team's issues and capacity
Trudy Claspill
February 28, 2024
In Jira Cloud what was "Shared Teams" under just Advanced Roadmaps Plans is now any Team defined from the Teams menu. Refer to
https://community.atlassian.com/t5/Advanced-planning-articles/Teams-in-Advanced-Roadmaps-What-s-changing-and-what-you-need-to/ba-p/2259096
You do need to create a Team under the Teams menu. You need to add the Team to your Plan. The Capacity for the Team within your plan needs to be set.
You do need to enable the Team field for the issues. You do need to set the the Team field for the issues in order for them to show up under specific Teams (rather than unassigned) when using the Group By Team option.
Donte Crawford March 25, 2024
Hello- I am attempting to 'Auto - Schedule' items in Jira Plans. Items that are in progress from the previous sprints. But the timeline is not bringing those stories forth. Any workaround?
Trudy Claspill
March 25, 2024
Please start a new Question post for your new question to ensure it gets good visibility from the community.
The only people that see updates to existing post are people who responded to it and anybody that elected to Watch it.
