Hey all!
Kinda self-explanatory title.
I'm playing around with Jira Dashboards, and intend to display some big numbers.
A nice view would be Story Points Committed vs Story Points Completed, basically how the Velocity Chart works, but displaying big numbers instead of the BarChart view.
Hi @Lucas Ferreira,
I am Marlene, product manager of Quick Filters for Jira Dashboards.
You could try out if the Quick Issue Statistics gadget of our app caters to your needs. With this gadget you can sum up any Jira number field (including custom fields), not just issue count.
You can try our Quick Filters for Jira Dashboards without installation on our demo dashboards.
Short answer: no, there are not.
You could create a filter for the issues in the open (current) sprint and another adding the status to show in two filter gadgets.
You could also check the Atlassian Marketplace for addon dashboard gadgets, as there are several which can display number counts like that. As you appear to be on the Free license level, it is likely you can find some that are also free for that user count. https://marketplace.atlassian.com/
