×I'm trying to build a dashboard using the Jira API. I'm able to get my list of issues using:
/rest/api/3/search
But when I update the assignee, it doesn't take effect into the API. the list of issues still says assignee: null
I'm using nextjs, and I noticed that if I delete the .next folder, and rebuild the site, the API data is updated. I'm trying to understand why this is happening? Or why the API response is being cached. I wanted to make sure that if there's an update in JIRA, it'll be updated in API without having to delete the .next folder.
No, there is no lag - if you make a REST call to update an issue, then the issue will be updated before you get the response saying it was successful.
@Nic Brough -Adaptavist- i'm kind of curious - how would you approach streaming the API call? like so if there's an update from JIRA, it'll also update on NextJS client side?
