  • Community
  • Q&A
  • Jira
  • Questions
  • Is there a way I can get roll-up dates from Epic items into an export file or Confluence database?
Karel van Leeuwe May 21, 2025
Roll up dates on your timeline | Jira Cloud | Atlassian Support
We use epic items to track the progress of deployments in various factories. I would like to get insights into the total lead time (start date --> end/due date) for every deployment and have that into a format that can be exported (to excel for example) such that I can start tracking metrics like "average lead time per deployment" etc.
I have made an overview into a Confluence database of all my epics, but in the database I can only get the start date + due date values of the epic if they are overridden into the epic itself, it does not show the roll up values.
Danut M _StonikByte_
Hi @Karel van Leeuwe,
Welcome to Atlassian Community.
I'm afraid that is not possible by using the native Jira / Confluence native tools.
A possible solution would be to search for an app (plugin) on Atlassian Marketplace.
If you consider the idea of using a plugin, our Great Gadgets app offers all you need for tracking the lead time of your deployments in an effective manner.
Control Chart - can display your completed deployments by their lead time. It displays the average and helps you easily identify the outliers and the ones that took longer than expected (by setting a threshold)
Trend Chart - can the average lead time of your deployments per past time intervals and the overall average. It helps you see if the lead time improves in time, form a week to another or from a month to another
Histogram Chart - shows the distribution of lead time your deployments and how many took longer than expected
WIP Aging Chart - shows the age (since creation) of your active deployments
All these gadgets can display a Data tab with details info for each issue, which you can easily export in CSV:
How to configure these gadgets for your use case?
  • as Data source use a JQL or filter that returns the epics that represent the deployments
  • Cycle stats: Since issue creation and Cycle ends: When the issue entered a status that has category "Done"
The gadgets do not use a Due field, but they can measure until the epic (deployments) reached a done status.
If you need any help with the setup, feel free to contact us at support@stonikbyte.com.
Danut.
Laura Campbell
Hi @Karel van Leeuwe and welcome to Community!
Could you explain a bit more what you are trying to achieve? That will help Community members better identify a good solution for you.
Since you mention a Confluence database, are you trying to track work items from Confluence?
Hi Laura, absolutely! We use epic items to track the progress of deployments in various factories. I would like to get insights into the total lead time (start date --> end/due date) for every deployment. In my original post I added images. I am using Jira to track epics, but I am using a Confluence database to get consolidated overviews. Let me know if you need more information.
