Is there a way in jira to create a word /pdf document of certain fields using automation?
Lalithesh Channu
Hello All,
Is it possible to create a word /pdf document when certain fields are filled out on an issue using an automation(either via manual trigger/ automated trigger)?
I'm aware that export action isn't available. Any possible workarounds to achieve this?
Thanks in advance!
Levente Szabo _Midori_
June 3, 2024 edited
@Lalithesh Channu Yes, it will be possible soon, as the cloud version of Better PDF Automation and Better Excel Automation apps are to be released very soon. Drop me an email at levente.szabo@midori-global.com so you get notified as soon as it becomes available!
Lalithesh Channu
marc -Collabello--Phase Locked-
Hi @Lalithesh Channu ,
There is no direct workaround in Jira vailable.
One option might be to send the data through a web request to an external system to do the PDF conversion.
Lalithesh Channu
Hello @marc -Collabello--Phase Locked-
Thanks for your reply!
Would you mind sharing more info on this.
Many thanks
You could use an external service like https://craftmypdf.com/pdf-generation-api/ (no affiliation, not vetted).
