Is there a way to bulk delete the inactive workflows?
Robert Colburn November 1, 2018
We have several JIRA projects buitl out and as changes were made backup were also made, now there is a large number of inactive workflows that need to be removed. I am hoping someone knows a way to bulk delete those inactive workflows, rather than removing them one by one...
Petter Gonçalves
November 1, 2018
Hello Robert,
You can use the add-on Script Runner and run the following Script to delete all inactive workflows (Except the default):
def workflowManager = ComponentAccessor.workflowManager
def schemeManager = ComponentAccessor.workflowSchemeManager
def sb = new StringBuffer()
workflowManager.workflows.each {
if(!it.systemWorkflow) {
def schemes = schemeManager.getSchemesForWorkflow(it)
if (schemes.size() == 0) {
sb.append("Deleting workflow: ${it.name}\n")
workflowManager.deleteWorkflow(it)
return sb.toString()
P.S: System default workflow should be assigned to some scheme, otherwise script won't work.
For more information about it, please check the question below:
How to bulk delete Inactive/Draft workflows
Randy Knight August 9, 2020
Getting the following when trying to run the above from Script Console.
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script1.groovy: 1: unable to resolve class com.atlassian.jira.compnent.ComponentAccessor @ line 1, column 1. import com.atlassian.jira.compnent.ComponentAccessor
Rabbit
Yeah, this is not working in Cloud with scriptrunner, alas.
Register Now
