Is there a way to configure JIRABot in Slack to only show specific fields?
Lee Correll
September 10, 2018 edited
So it's nice that Slack hyperlinks the entries for a specific project - but i don't want the specific fields that are being shown, I want to be able to edit those fields - ideally, I just want the hyperlink and ignore the other fields.  Is there a way to control that?
Lee Correll
September 28, 2018
Yeah, sorry, my opinion of Atlassian "voting" is that it's a sham and a way to get the users to think they have some degree of input into the product moving forward - there are items voted on years ago that Atlassian cares not a whit about.  We've already gone with a 3rd party Slack product.  Thank you anyway.
Prince N
September 28, 2018
Hi Lee,
Currently, you won't be able to specify which field is visible as notifications on Slack from the Jira Cloud Slack Integration other than the filters being used presently.  As there are two options for issue preview which are "Clean" and "Compact". There is a feature request on Ability to customize which fields will be displayed on Slack notifications which is still open, we suggest you watch and vote on it to get notified when it's updated.
Hope the above helps.
Prince
