Is there a way to create a boolean custom field?
Tai Thach
July 23, 2012
5 votes
Jobin Kuruvilla [Adaptavist]
July 23, 2012
Look at checkboxes. It is pretty much like boolean!
Nic Brough -Adaptavist-
July 24, 2012
Exactly what I do - a multi-check box field with a single option will behave precisely as a boolean.
You can be more explicit with a radiobutton with 2 options, but that isn't quite as pretty.
Like • Vander likes this
Thomas Wendel
November 13, 2012
I stumbled over this question because I was looking for a boolean field as well.
From my point of view a simple multi-checkbox with only one option is not good enough. While a multi-checkbox with a single option is pretty much boolean, it only shows up when the checkbox is checked. Unless there is a way to make JIRA display empty fields as well, this is not an option in my case.
I tried the approach with radio-buttons or a select-list, both with the options "yes" and "no". However, in both cases I can not get rid of the "none" option, which makes this approach not boolean anymore. And like the multi-checkbox, having just "yes" and "none" is not cutting it either, because "none" is, again, not shown at all.
So, does anybody have another idea?
Thomas
November 13, 2012
Yes, but you'll need code. I think it's as simple as extending a standard custom field that always stores "true" or "false" and never a null, then making the .vm to display/edit it pretty.
Thomas Wendel
November 13, 2012
Nic, I agree. It would not be a difficult task to implement a plugin with a new custom field which is truly boolean. The only problem is that our cusotmer is on a tight budget which won't allow the development of even such a simple plugin :-(
Tanner Wortham
July 23, 2012
I know of no way to create a boolean custom field, but maybe a plugin like this providing booleans in workflow transitions might solve whatever your problem might be:
https://marketplace.atlassian.com/plugins/com.tng.jira.plugins.workflowenhancer/version/7
Naren
November 13, 2012
Hi Thomas, you can get rid of the 'None' value from the Select List and Radio button customfields and making fully boolean, please go through this link -
https://confluence.atlassian.com/display/JIRA/How+to+Remove+%27NONE%27+from+a+Select+List+Custom+Field
November 13, 2012
I don't think that does it because the "none" display is stored as "there is no data here" in the database.
When the field is displayed on-screen, then it doesn't show as "none" or whatever you change that to, the whole field is skipped completely.
In other words, if you have a field set up as boolean values, you say
"True" = True (this will work fine)
"False" = none/empty (and will not be displayed)
An issue with "true" set will show "true". An issue with "false" set, won't even display the field name, you'll get nothing on-screen at all.
