Is there a way to default the Fix Version for a project?
Liz Neiley August 14, 2013
I am a newer admin user to JIRA. I have searched several pages and couldn't find the answer. I'm under a timeline to get this address. I would like to default the fix version on the project because right now most of them are blank. I have updated the existing ones, but would like to prevent this from happening in the future. While I can require the field, I would like to default it to save users time.
RambanamP
August 14, 2013
you can't set default values for system fields for this feature issue has submitted
https://jira.atlassian.com/browse/JRA-4812
you can try with JavaScript or using post function you can fill the version
Liz Neiley August 15, 2013
Thank you for the response and the link to the request.
Jason Yip
August 2, 2018
As far as I can tell, you can't set the Fix Version via post function either.
Sasa Stojakovic May 27, 2019 edited
My response is probably coming late but I would like to share my workaround.
I simply created a custom field which is based on values provided in Version (Project Settings), I created a context for this field related to the project and there I was able to define a default value for this custom field. A the end I just copy value from this field to fixVersion field during issue creation transition. I used a plug-in workflow post function but it is may available in native Jira post-functions.
No code required and works fine!!
Błażej O_
August 15, 2013
I think you could do something like this with Behaviours plugin.
You set a certain scripted behaviour depending on values of desired fields.
We use almost identical script to set summary depending on issuetype chosen, however I'm not sure if this would work on multi-value field like fix version. Therefore please test it on the test environment before launching on the production ;)
import com.atlassian.jira.issue.IssueFieldConstants
import java.util.List
import com.atlassian.crowd.embedded.api.User
import com.atlassian.jira.ComponentManager
User user = ComponentManager.getInstance().getJiraAuthenticationContext().getUser()
FormField formFixVersions = getFieldById("fixVersions")
FormField formProject = getFieldById("project")
if (formProject.getValue().contains("XXXXX-the-5-digit-code-of-your-project"))
    {formFixVersions.setFormValue("Your-desired-version")
else
    {formFixVersions.setFormValue("")
You can get the 5 digit code of your project for example from the projects administration screen, when you hover over "edit" links on the project list.
Liz Neiley August 20, 2013
Thank you for your response. Unfortunately at this time, we do not have the Behaviours plugin. I will be going with making the field required and setting a change in business process to make sure the reporting is accurate.
