×Hi,
we've got a problem with an issue where a user change the remaining estimate by mistake:
Is there an option to delete it in the history? Because we've got now a problem if we want to evaluate the time:
Thank you!
Hi @Kaja Iske You can't delete Issue History as it is used for issue audit to track the changes on the issue.
You can clone the issue that option is available as sometimes issue has more data like comments and most of the work is already completed on that, if possible clone the issue after updating the field value what you want and delete/archive the original issue.
The history in the clone issue will clear, other field data details will be retain.
Ravina
Hi @Kaja Iske
There is no option to delete history entry.
Also, there is an open ticket related to it. Please watch and vote: JRASERVER-69002
