Is there a way to export all the dropdown options for a custom field in Jira?
Wendy Grapentine
March 12, 2024
I have a custom dropdown field in Jira called "Customer Name" where we (obviously) put the names of all of our customers who are financial institutions. Is there a way to export all the customer name options under that field into an excel sheet?
Tuncay Senturk _Snapbytes_
Hi @Wendy Grapentine
Yes, you can export the options for a custom dropdown field in Jira to an Excel sheet, but it requires a few steps because as far as I know, Jira doesn't provide a direct "export to Excel" feature for field options out of the box. So I'll try to offer a couple of options which might be helpful for you:
Manually copy-paste
  • Go to Jira Administration (cog icon) > Issues.
  • Click on "Custom fields" under the Fields section
  • Locate the "Customer Name" field and click on the "..." next to it, then select "Contexts and default value."
  • if you click to edit the options for the field, you should be able to see all the customer names listed where you can manually copy these names and paste into Excel
Use Jira REST API
  • Find the custom field ID by navigating to the custom fields section.
  • Use the REST API endpoint to fetch the field options. /rest/api/3/field/{fieldId}/context/{contextId}/option where {fieldId} is your custom field ID. and the {contextId} for which you want to get the options.
  • You'll receive a JSON response with all the options. You can convert json to excel by simply googling a free online tool.
Best
