Is there a way to get different users to execute the same test case in a Test cycle in AIO
Tester G
September 26, 2022
Hi I have multiple Business testers who would be testing the same functionality as part of UAT. Is there a way to assign the same test case a test cycle to multiple users.
I see there is a multiple RUN option for in a test cycle, however, I want to assign the same test case to multiple users at in a test cycle for simultaneous execution, without duplicating the test case itself.
Is there a way to achieve this in AIO?
Noopur Varshney _AIO Tests_
Hi @Tester G ,
Currently AIO Tests doesn't support assignments/custom fields at Run level. So it is not possible for multiple testers to execute same test case in the same cycle.
The recommendation is to create separate cycles for each business tester with the same cases. You can create the first cycle and then make copies.
Also, while running reports, you can use the Multi-cycle reports as well as for Traceability reports you can use "All Runs strategy to pull results from all UAT test cycles.
You can reach out to us at help@aioreports.com or via our support portal. Here is our documentation link too.
Noopur (AIO Tests Team)
Read the story
