Hi @Ajita Kopparapu
Not natively, there's no field-level permissions in Jira.
I've seen a few different alternatives used to do this, in particular...
Workflow Screen
- Add the field to a Screen only editable in a Workflow transition. This means it's only possible to modify the field during that Status change.
- Split the main Screen between different Issue Operations (using the Screen Scheme), with a View screen containing Acceptance Criteria, and Create/Edit Screens not including it.
Automation
- Create an additional paragraph custom field - Accepted Acceptance Criteria
- Create two automation rules...
- The first rule copies the value of Acceptance Criteria to the new custom field, when all parties have agreed. A trigger would be needed to activate this (such as a Status change).
- The second rule checks updates aren't being made to Acceptance Criteria. If the field is modified, it will check the value still matches Accepted Acceptance Criteria - if not, it will alert relevant parties via email/comment.
Let us know your thoughts - and if you need more detailed instructions, let us know!
Ste
