Is there a way to make it check if 2 fields match before transitioning?
Yousuf Al Rawahi
Is there a way to make it check if the assignee field matches the 'Staff Name' field (custom field) before transitioning from status to another status? If it matches then it will transition to another status, otherwise it will stay in the same status.
Maciej Dudziak _Forgappify_
April 14, 2024
Hi @Yousuf Al Rawahi
In Jira out of the box, it won't be possible. But it should be quite easy using any 3rd party Jira expression-based validator / condition (assuming you are using company managed project)
The expression will depend on the type of your custom field. If it is a User Picker, then it should be straightforward like
issue.assignee.accountId == issue.customfield_xxxxx.accountId
 where xxxxx is the ID of the 'Staff Name' field
We've developed the Jira Expression Validator as part of the free  Workflow Building Blocks for Jira  app, which can help you in writing such expressions. I would appreciate it if you could give it a try.
Cheers
Yousuf Al Rawahi
It worked!
4 votes
Ste Wright
Not natively; you'd need an App to expand the available workflow conditions to restrict a transition based on two fields matching.
Check out Apps on the Marketplace such as...
Natively, you might be able to do this via Automation, depending on the logic...
  • If the transition should happen automatically once the fields match, you could do this just using a rule - i.e.
    • Trigger if either field value has changed
    • Check both fields match
    • If they do, transition the issue
  • If the transition is manual, but would rely on the two fields matching, you could...
    • Create a custom Checkbox field - eg. Fields Match? - with one option "Yes"
    • Populate the field using an automation rule...
      • If they do, check the box
      • You might need a separate rule to uncheck it if the fields no longer match
    • Set a condition on the workflow - the "Value Field" condition - to check "Fields Match?" equals Yes
Let us know if either option is of interest!
If you need any additional help to set either of these up, we'd be happy to help :)
Ste
Neel Mohapatra _Appfire_
April 14, 2024
Hi @Yousuf Al Rawahi ,
You can also make use of JMWE with the help of build your own scripted validator
It could look something like below:
You also have the option to add conditions; for example, the two-field comparison should only be made if the assignee is a so-and-so person or if a filed value is something.
you can raise a support ticket with us, if you need any assistance.
Good day!
Learn more
