Is there a way to prepare a link that would prepopulate the Project and Issue Type?
Donna Macauley
Looking for a way to create a link that would automatically bring the user to a create screen with the project and issue type already selected.
2 accepted
John Funk
Hi Donna,
From within Excel it would look something like this:
=HYPERLINK(CONCATENATE("https://YOURDOMAIN.atlassian.net/secure/CreateIssueDetails!init.jspa?pid=17611&issuetype=3
Obvously, you would put in your domain. And PID would be the ID of the project and 3 in this case is the ID of the issue type.
To find the Issue Type id, I go to Settings > Issues and search for the issue type.
Then do an Edit for that Issue type. In the URL address will be the ID.
For the project, I go to the list of projects and search just for that project. Then do an Inspect in the browser and search for project_id
There may be easier ways to find those - like with the API, but those work for me. :-)
Donna Macauley
For Project ID:
Gear > Projects > Select your project > Actions > Project Variables > look at URL
Like # people like this
Donna Macauley
Thank you!
Like John Funk likes this
Ravi Sagar _Sparxsys_
September 17, 2020
Hi @Donna Macauley
Try this url.
http://JIRAURL/secure/CreateIssue.jspa?pid=10002&issuetype=10102
Of course replace the pid and issue type id.
Ravi
Mickaël Orsolino
Ravi answer works well. You can also prefile customfiled also by using ID.
Mickael
Donna Macauley
Thank you! This is exactly what I was looking for.
SERVER
VERSION
8.11
