I am looking for a query which allows me to search issues based on Response Priority
If it's changed from P1 to P2, the issue gets updated and there is no way to filter issues which were P1 at one point of time
Getting error: History searches do not support Response Priority
Note: Response Priority is a custom field - Single List (single choice)
issuetype = Escalation and ("Response Priority" changed from P2 to P1)
Unfortunately, history searches are not supported on custom fields so you won't be able to do so with JQL.
I think your custom field may be listed in the Field Value Changed trigger in automation rules, Please have a look once, and that may be the easiest way to detect this, and then take action.
