Hi All,
I would like to know whether transition id can be moved up or down during the workflow. For example, In my workflow i have transitions in the following order,
Analysis in progress --> Code change needed
Analysis in progress --> Cancel
Analysis in progress --> Hold
Analysis in progress --> Doc change needed
Analysis in progress --> Invalid
I would like to rearrange the above order. I want to move 'Doc change needed' may be after 'code change needed'.The reason being, buttons on the workflow transition are displayed based on the 'transition id' order. I want my 'Doc change needed' and 'code change needed' to be available as top options for the workflow.
Is there a way to achieve this ? please let me know.
Vijay
Yes, you can set an opsbar.sequence property on each transition and JIRA will put them on your menu in low-to-high order (I think it's low-high, from memory) - most of us set values like 10, 20, 30 rather than 1,2,3 so it's easier to re-arrange them later.
Hi Nic,
Thanks for your response. I was able to implement the reordering of the transitions. I had to apply for all the transitions in the workflow to make it work.
Vijay
