I have installed the toggl button chrome extension and can start a timer from a jira task but is it possible to sync the timer to the work log so that I have an idea of time spent on the task within jira?
If not possible with the toggl button can anyone recommend a solution?
Hi @jane pulman
Can you please share the link to the toggl chrome extension? Maybe there is an option to sync it with the work log as part of the extension.
I don't think that there are options. and there's no solution to sync with toggl and jira work log. but I definitely hope to have.
Register today
