Using Assets in Jira Service Management. Is there an API for editing attributes of an asset via automation?
Hi @Thomas Currie ,
For Assets you can use the build in components/actions for Assets too and don't really need to use the API.
https://support.atlassian.com/cloud-automation/docs/jira-automation-actions/#Edit-object
If you really do want to use the API you can use a web request action using the REST API for Assets
Hey @Thomas Currie ,
I'm trying to set up Assets and am curious what your use case is. How are you planning on using the API? Are you automating anything?
