Is there any report which should fetch data of resource level time spent.
It should show original estimate for the resource and time spent for the task
original estimate and time logged level it should for the particular resource
You will need an addon to achieve this or try to create a custom report in Excel or google Sheet using the rest api
Thanks for the details.
Can you name that add-on also is the process for the add-on Also suggest on API
Register now
