×Hello,
I want to know if there is any required minimum version of Jira datacenter for migration from cloud to datacenter.
Now we are using 9.12.7 version of Jira datacenter and another Jira instance is running on Jira cloud.
We plan to migrate cloud Jira instance to datacenter version.
So I want to know if there is any required minimum version of datacenter to migrate one cloud instance to datacenter.
Thanks.
Hello @Jongho Jung
I found this document concerning migrating from Jira Cloud to Jira Data Center v9.12
I found versions of this document back to Jira Data Center v8.20. I didn't look for anything older than that.
Are you going to try to migrate to a older version than that?
Note the warnings in the documentation about loss of functionality/features in this sort of migration, due to Jira Cloud often having functionality that is not available in even the newest version of Jira Data Center.
Thanks for your kind answer.
We plan to migrate to v9.12 so I believe it can be.
Thanks.
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
