Is there any way to create a custom field which shows sum of two numbers from other field?
Miki Yuzawa May 22, 2012
The last two numer in the screenshot represents "Business Value" and "Technical Compexity." I would like to add another cusotom field to represent the sum of two numbers. Is this possible?
Thank you!
Miki
Jean Resener
June 18, 2012
We created a scripted field using a groovy script, but Greenhopper doesn't support it either. can't add it to a card/summary/list view. In fact, when trying to ORDERBY the field there are problems. We are hoping GH will support it, because we have to run queries and export to excel to get the views we want. *sigh*
Jean-Pierre Chiri
take a look at groovy script : scripted Fields
https://studio.plugins.atlassian.com/wiki/display/GRV/Scripted+Fields
Thomas Schlegel
Hi Miki,
look here: https://answers.atlassian.com/questions/31441/how-do-i-use-calculated-number-fields-in-greenhopper
it seems, you can create this field with the JIRA Misc Custom Fields Plugin, but you cannot use it in GreenHopper.
Best regards
Thomas
Miki Yuzawa May 30, 2012
Hi Thomas,
Thank you for your reply.
OK, we cannot use the feature in GreenHopper :(
Miki
Let's build A Rovo Agent 🤖
Save your spot
