×We use Tempo plug-in.
when we planning through timesheet, we cannot make plan about activity directly
we are able to planning just using configuration icon like below picture
image2017-1-16 14:15:44.png
but we can make plan at component not using configuration icon
image2017-1-16 14:15:19.pngwe just point the day that we want to plan
by the way, we don't using planning at component
However, it is often make mistake because it is easier to make a plan for a component,
So. we want to block component planning
Is there any way to prevent planning at component ?
Hi Jeongmin Lee,
Assuming you mean the Tempo Timesheets for JIRA add-on, you might be better contacting the vendor, Tempo for JIRA, via their support portal here: https://support.tempo.io/hc/en-us/requests/new
In the meantime, I've tagged your question to try to increase the chances that someone will answer it here on the general community forum.
Sam
