So that I may make an edit on Azure & it gets reflected on Jira or vice versa.
Question no, 2: If I go for a connector, which is the best one to use?
Hi @Aleena Umaiir and welcome to the community,
Syncing issues between 2 different instances is a real tedious task. I would recommend any other approach but to use dedicated apps like Exalate or "Backbone Issue Sync for Jira". At our company we use and recommend Exalate. But both of them will get the job done.
You are welcome! :)
